New #s; P-1 on stock bottom end LS1
Old 04-05-2009, 05:41 PM
DarkFormula's Avatar
Default New #s; P-1 on stock bottom end LS1
P-1SC-1 @13psi, stock bottom end, 6.0L LQ9 heads, Comp Cams XER blower cam, IPS FMIC, MAC mid-lengths w/ true duals. I've been running this setup for seven years now.
I have a track day on the 24th, I cannot wait
Old 04-05-2009, 05:45 PM
Silver_TransAm's Avatar
7yrs at that power level?
Old 04-05-2009, 06:03 PM
allthrotle's Avatar
Those are nice numbers, Im way to scared to push that much boost on the stock bottom end. You sir have a brass pair.
Old 04-05-2009, 06:29 PM
Seven years with this Procharger setup, four years making over 500rwhp and revving to 7k RPMs.
Old 04-05-2009, 06:36 PM
'Trust''s Avatar
Pretty impressive man!
Old 04-05-2009, 06:48 PM
dudeman's Avatar
out of those 7 years how many years was it sitting in your garage not being driven?
Old 04-05-2009, 08:16 PM
November to March of each year sometimes until April depending on weather.
When I do drive it, it gets the ever living **** beaten out of it. I have eight 1/4 mile tracks within 2.5 hours of me. I live ten minutes from one of them, if that gives you a good idea.
Old 04-05-2009, 08:25 PM
SMahar28's Avatar
let me know when you blow it up=)
Old 04-05-2009, 08:34 PM
Won't happen, this was a Wednesday car
Old 04-05-2009, 08:52 PM
OUTLAWZ RACING's Avatar
Dam good tune and the heads help and the cam way to go!
Old 04-05-2009, 09:00 PM
The very top end was leaned out a tad bit after the last pull. The dip between 4k and 4500 is an area between two cells, the car is setup as speed density. There will be more tweaking.
Here's a pretty current mod list:
Quick Reply: New #s; P-1 on stock bottom end LS1
