kee audio vs. stock replacements?
Moderator
http://keeaudio.com/id79.html
Stock speakers are shot, or something else is wrong with the system. Looking @ replacing the front door speakers ($199 on ebay) Or getting the set above?
Anyone who used the kee system, is it a plug & play. Did all the factory connectors just plug in?
Speaker mounting holes line up perfectly?
Sound VS stock speakers?
Better place to find stock replacements?
IMHO, there is no better place for speaker replacement period besides Ian@Kee Audio.
He hooked me up on a big CDT system complete with EVERYTHING i need for the install. Cant beat the service or price.
Do not buy the stock replacements. That is the worst possible use for your $200. Spend a little extra money and buy what Ian has to offer. You will never regret it! Ian is awesome to work with and CDT speakers beat just about everything out there!
Get The Kee Audio Standard Package Dude
The holes are ever so slightly off, but I didn't need to drill out anything or modifiy anything at all, just screw the screws in and they will straighten themselves out. Also, I believe you will have to solder the wire on which isn't hard at all. Or u can do what I did which is cut the connecvtion off the old speakers and solder that onto the new speakers so if u ever want to replace them, it is much easier aand u won't have to go looking for connectors. And I must add the sound quality is MUCH better than stock IMO. Also, Ian is great to deal with and the customer service is second to none!
I just clipped the wire harness off the stockers and crimped on spade connectors to put them on the CDT's. Only problem is finding the mini spades for the neg hookup. Luckily I have a electronics supply near my house.
Moderator
I think I'll go stock replacements. They state that the replacements are better made and will not blow like the stockers did. I had no issues with the stock sound. Just that the speakers seem blown now.
Well, its your money. Bu I figured since I was about to drop that much on replacements, why not go all the way and get something that truly sounds top notch. For instance, I got the CDT ES-62iS and couldnt be happier. Those components are a steal now on sale, I paid more for them. So why not get those, some dynamat for the doors, maybe some affordable midwoofers and a smaller amp 300-400w?
O.o you can buy speakers that sound much better for less so why are you getting stocks again?
GM/Delco did not go out of there way to make new improved stock replacement speakers for a car that hasn't been made in 7 years.
Just a heads up.
Although I usually recommend Polk DB speakers for upgrades, I cant blame the OP for wanting to keep the same sound. Lets be honest, The factory system is a great factory system which works well together. Some of the biggest problem with just changing speakers in the monsoon system is the change in volume on the rear sail panel speakers, and the Tonality. My recommendation would be to either keep it all stock, or change out the Radio AND the speakers.
Ungrounded Moderator
Granted, there is lots more you can do if you want to add/change amps, speakers, and head unit but if you're just looking to fix the factory system this is a great way to improve quality without spending a fortune.
