Car wont idle after starting..
Old 04-05-2009, 06:21 PM
skeeters65's Avatar
Default Car wont idle after starting..
Car is a 69 Camaro with 2002 LS1 with MS3...
When the car first starts up weather it is cold or hot it barely idles and will almost stall.. But after I drive it down the road a little it idles perfect..
Computer is throwing a p0106 code.. IS this related or different problem? Bringing it to the tuner this week to have MAP parameters adjusted for the cam..
Thanks
Old 04-06-2009, 06:03 AM
Eagle Performance's Avatar
Not sure what code that is, but going to a tuner, assuming they can do it right, should solve both problems.
Old 04-06-2009, 08:06 AM
skeeters65's Avatar
Seems like it dumps too much fuel when it starts and needs to be cleaned out before it will run right..
Also smells like unburnt fuel on start up..
Thanks
the p0106 is a MAP sensor code..
