coated header question
It should be noted that the primary intention of ceramic coating is to increase scavenging. No coating can 100% prevent rust from happening, although they do delay the formation of rust. If you want rustproof headers, pick up a stainless set.
You are just as likely to melt wires with ceramic coating as without. While they do reduce header surface temps, they still get way hot - enough to melt silicone and plastic.
will this give me the same protection as coated headers http://www.designengineering.com/pro...FQzxDAodJwMZWg
From what I hear, wrapping headers is generally a bad idea if you're concerned about their longevity. The primary benefits of ceramic coating are performance related. If you can afford it, get some stainless headers and have them coated. Then you won't have to worry about rust, and you'll get the benefits associated with ceramic coating.
Assuming that coated headers won't melt your wires, or anything else that could come into contact with them, would be a mistake. They will keep the engine bay cooler, and the surface temps of the headers should be much lower assuming they're coated inside and out, but I'm sure they will still get hot enough to melt some things if they were to come into direct contact with the header.
I'm assuming you meant to ask whether it was OK to run uncoated headers, and I'm sure there are probably a lot of people running uncoated headers. Your original question was why are coated headers better.
If you didn't see any wires near the headers, does this mean that your car already has headers? Are you replacing them?
Exactly,
If you don't want to melt wires I would recomend getting an over the valve cover wire setup (OTVC). Yes, ceramic coating is more for scavenging the exhaust flow away from the engine quickly. After a year or two surface rust will start to form on ceramic coated headers.
I forgot something, with ceramic headers if that is what you are planning. You can't install the O2 sensors right away because they are coated on the inside as well. When the coating is headed up initially, ceramic particles will break off the steel and flow down your exhaust. They particles can poisen O2 sensors and you will have to replace them. You would have to ask people with coated headers what they did for the first few weeks, I would assume just buy two plugs to fit into the O2 bungs and then install the O2's after a few weeks.
