Numerous C6 Parts Wanted
I have a local dealership connection, but if any of you have these parts I'd like to take them off your hands over buying new. Thanks!
- Alternator
- LS2 Coil Packs and Associated Harnesses
- Driver Side Ext Applique (lh15207548) - the exterior trim piece on the driver side A pillar
- Braided Fuel Line to Fuel Rail
- 2005 C6 MN6 Engine Harness - 19115749/19115748
- Side Reinforce (to tab in fender to nose) - 11517700 need 4
- Fender Reinforcer - 15230686-5 need 2
- Fender Mounting Stud - 25651470 need 2
- Front Harness (front lamp harness) 15832661
- Side Hood Seal 15774161 need 2
- Brake Booster Check Valve/Grommet - 18022219,18060007
- Power Steering Reservoir/Cap - 26046502, 10317982
- Power Steering Hose - 26046910
- Valve Cover Gasket - 12560696 (just need one)
- Positive Cable from Battery
- Oil Filler Cap and Neck - 12577268, 12559505
- Dip Stick - 12570787
- Wiper Arms - (R-15147566, L-10445313)
- Wiper Arm Nut Cap - 10341324
- Washer Nozzle Hoses - 10322790
- Plenum Screen (cowl top) - 15822873
- Air Inlet Grille Extension (drivers cowl end) - 15213128
- Alternator
Updated need list:
- power steering reservoir/cap/the hose off the reservoir below (the 1/2" one)
- alternator
- maf
- boot over steering knuckle
- large grommet over clutch assembly through firewall
- braided fuel line
- EVAP system (the parts up on top of the engine)
