line lock start.......
does anyone use their line locks to keep the car (M6) from rolling through the lights while holding the revs before their launch. a coroker said thats what they are made to do on M6 cars not just to help in the burn out box. i know of some tracks you have to be careful of rolling but... tell me what you all think
Race your car!
If the switch was hooked up to the clutch pedal so that it will hold the car while the clutch is depressed that would work, you'd need a switch to work it as well for the burnout though.
Honestly though, being that every track has a dead level starting line if you are rolling forward with the clutch in and the rpm's up that means the clutch is dragging and you have a clutch problem. With the pedal all the way down the car should not creep forward at all... if the thing is set up right that should never happen.
Race your car!
Sorry... I haven't been to any of your local stuff.
But, some of the places I've been weren't killer like etown, but for the most part what tracks we do have are pretty good, starting line's are all level anyway. Or at least close enough so the car's don't roll on their own
The linelock on a swtich with the clutch pedal should work fine though I'd think. Just better hope that it doesn't get stuck on or you might have a bad day.
I had mine connected to the output on my Harlan 2-step, which was deactivated by the clutch. I had a switch between the 2-step and the line lock so that I could turn on the two step, roll into the beams, apply the brakes, and flip the switch. With it setup that way I could use the 2-step without activating the line lock if I wanted to.
