fuel pump wiring
Need to know what harness you have to say for sure, but this should get you started
This is the fuel pump relay for a 3rd gen f-body
Ignoring the majority of it, you see there's basically a 12V in and a 12V out to the fuel pump albeit mislabeled in the diagram (Relay failure not ECM)
Remove the relay and jumper the terminals; not being a 3rd gen the pins will not be the same, but the colors/functions should be if you are using a GM harness
Alternately you can use the test lead if your harness is equipped and you can locate it
sorry the car is a 2001 ws6 trans am. I was wondering why i was not getting a reply....if my relay is clicking... I must be loosing power after? Or would that mean that it is dead at the tank?
