View Poll Results: Should i stick with the ATWI or should i use a FMIC
ATWI
1
100.00%
FMIC
0
0%
Voters: 1. You may not vote on this poll
Some intercooler questions (with pics!)
Old 04-06-2009, 05:35 PM
WSsixed's Avatar
Exclamation Some intercooler questions (with pics!)
Ok so the first box of turbo stuff finally showed up on Friday and in the box I found a ton of connectors and hoses as well as an Air to water intercooler as well as a tank and some other part that I’m really not sure what it is. First off I thought the kit came with an air to air fmic but I guess I was wrong or they changed the way there building the kit. My question is will an air to water intercooler be ok for a mostly street driven but some track use application? Also it gets cold here during the winter is it ok to run it with coolant? And where will the pump and tank be mounted? And there doesn’t seem to be any way for the hot water in the intercooler to be cooled would I need to add a radiator to the system or something?
Sorry for all the noob questions everybody.
This is the part that I have no idea about lol
Old 04-06-2009, 08:25 PM
WSsixed's Avatar
Bump!
Old 04-06-2009, 08:31 PM
dudeman's Avatar
where did you get that air filter and how much. i need one.
i just read somewhere, probably here, that a2w is great for a drag car but will do fine on the street. you will need a pump to circulate the water to keep the iats down or something like that.
Old 04-06-2009, 08:32 PM
dudeman's Avatar
here it is.
https://ls1tech.com/forums/forced-in...-ebay-one.html
Quick Reply: Some intercooler questions (with pics!)
