Rears are 315/35/17... Will FRONT 255/45/17 look ok?
I have 315/35/17 DR tires on the rear mounted on 17x10.5 rims.
Up front right now I have 275/40/17 on a 9.5 rim.
I want to run a skinnier tire up front.
I pretty sure a 245/45/17 will look stupid on a 9.5 rim.......
how does a car look with 255/45/17 up front and 315/35/17 in the rear?
I know the aspect ratio is different.......
IMO its gonna look really bad, the tire will be to narrow for the wheel and suck in the side walls, then you will also lose your bead protection on your wheel, also the side wall will be taller than on the rear so it wont look proportionate, to me the 275/40-315/35 combo is perfect, but thats my opinion.
the pic in my sig is 275/40's on 9.5's in the front, a 255/45 wouldn't look right to me, I think mine are just barely wide enough, my BFG's look way better than the sumitomos it that same size.
OP you'll be pissed the first time you scrape the **** out of a wheel when you could have saved it with a wide tire, ask me how I know..... thats why I mentioned you lose your bead protection. I didnt even go with a narrower tire, just a different brand of the same size.
you are wrong. i know how tire sizes work. i have been selling and installing them for 8 yrs. not to mention been to more training schools via michelin and bfg and bridgestone then i care to mention. the first number is the width in mm. period. the second number is the aspect ratio and is a percentage of the width. so a 45 series is taller then a 40 series but if they both are a 245 they are the same width.
and in the shop I have always noticed a smaller aspect ratio gives a wider footprint, so even though its measured a certain way what you end up getting is still different.
edit: ok it is measured from sidewall to sidewall, sorry about that, but you know that when you take a tire that has a smaller aspect ratio they always are a bit wider, why the hell they would measure the width at the sidewalls I dont know but it does end up affecting the width of the tread. I was going off of what I have seen in the past 10 or so years of mounting and selling them also, I never had formal training on them just experience in the shop, and again, a lower aspect will give a wider tread width in reality, maybe not on paper.
not on the same rim. you have to take that into account. for every .5" change in rim width the tire width changes approx .02" in section width. if you use the same brand tire, on the same rim, they are the exact same size. just the taller tire is going to "look" diff due to likely close to an inch in overall diameter.
