Torque Specs
Old 04-06-2009, 06:51 PM
lilpb1's Avatar
Default Torque Specs
This is a newbie question but search didnt work for me. Im installing some headers but dont know the torque spec for the header bolts. What would you guys recommend? Also would you recommend threadlock?
Any help would be appreciated.
Old 04-06-2009, 08:11 PM
99345hp's Avatar
I wouldn't worry about torque specs for header bolts. I think it is around 25 lbft or something like that. You will have to tighten them again after a couple heat cycles.
Old 04-06-2009, 08:14 PM
Benner's Avatar
Spec's straight from GM via Alldata
Notes
Bulletin No.: 06-06-01-026
Date: December 22, 2006
INFORMATION
Subject:
L59, LR4, LM4, LM7, LQ4, LQ9, LS1, LS6 New Exhaust Manifold Bolts and Torque Specifications for GEN III Vortec(TM) Engine
Models:
1999-2003 Cadillac Escalade
1999 Chevrolet Forward Control Chassis, P32 R/V Van Chassis, P42 Commercial Chassis
1998-2002 Chevrolet Camaro
1999-2003 Chevrolet Corvette, Express, Silverado, Suburban, Tahoe, W-Series Medium Duty Truck
1999 GMC Forward Control Chassis, P32 R/V Van Chassis, P42 Commercial Chassis
1999-2003 GMC Savana, Siera, Yukon, W-Series Medium Duty Truck
2003 GMC Siera Denali
1998-2002 Pontiac Firebird Formula, Firebird Trans Am
2003 HUMMER H2
1999-2003 Isuzu N-Series Medium Duty Truck
with GEN III Vortec(TM) Engine (VINs V, G, P, S, T, N, U, Z, - RPOs 4.8L, 5.3L, 5.7L, 6.0L)
A new exhaust manifold bolt and torque specification was introduced to the GEN III Vortec(TM) small block V8 engines beginning with the 2004 model year. When servicing any GEN III Vortec(TM) small bock exhaust manifolds, the exhaust manifold bolts should be replaced.
- P/N 11518860 Exhaust Manifold Bolts
Apply a 5 mm (0.2 in) wide bead of high temperature threadlocker to the threads of the exhaust manifold bolts before installing.
- P/N 12345493 - GM High Temperature High Strength Threadlocker (U.S.)
- P/N 10953488 - GM High Temperature High Strength Threadlocker (Canada)
When tightening the exhaust manifold bolts it should be done with two passes. First tighten the two center bolts on the exhaust manifold. Then tighten the rest of the bolts, alternating from side to side, while working towards the outside bolts.
Install the exhaust manifold bolts.
Refer to the following torque sequence:
Tighten
Tighten to 10 N.m (89 lb in) on the first pass.
Tighten to 20 N.m (15 lb ft) on the final pass.
Old 04-06-2009, 08:25 PM
lilpb1's Avatar
Thanks for the input.
Old 04-07-2009, 12:46 PM
lilpb1's Avatar
Anyone know the size for the bolt or the part number for autozone? Need them ASAP.
Old 04-07-2009, 05:17 PM
DarkhorSe_SS's Avatar
Just go to the dealer. I got some yesterday for $1.76 each
Old 04-07-2009, 06:42 PM
lilpb1's Avatar
Thank I just went with some Stage 8.
Old 04-07-2009, 08:30 PM
talked to Tsp Yesterday and they mentioned they don't work to good.
Not sure
Old 04-07-2009, 09:07 PM
Benner's Avatar
In case your still interested, looks like there M8 x 1.25mm x 22mm
Old 04-08-2009, 10:44 PM
lilpb1's Avatar
Thanks Benner and the Stage 8 worked good.
Old 04-08-2009, 10:59 PM
gold98Z28's Avatar
this should be all the tq specs you will ever need for a ls engine but i never tq headers
Old 04-09-2009, 08:37 AM
lilpb1's Avatar
Good info.
Quick Reply: Torque Specs
