Looking For LS1 Block
i have a 5.3l iron block that i just bored and honed .120 over to 99mm (stock ls1) block has been jetcleaned/hottanked and the decks have been checked for warping. new cam bearings have also been installed. the main caps were also bolted on and checked for trueness. i would like to get rid of this block with everything that came with it... stock 5.3 heads (bolt on for higher compression ratio) stock rods (sams size as LS1) cranshaft which has been micropolished, hottanked and magnafluxed for cracks. front and rear cover, oil pump, pickup tube, oil pan, and valvetrain. not sure if you can use this stuff but im just throwing it out there. thanks.... Matt
