How much can you mill 317s...
Old 04-07-2009, 07:38 AM
BlackTA96's Avatar
Default How much can you mill 317s...
Im looking into getting a MS3 for my 6.0
How much can you mill the heads down and still have enough PTV clearance with that cam? I want to bump the compression up a little.
Also,
Is there a particular head gasket you guys are running?
Old 04-07-2009, 07:53 AM
smask04C5's Avatar
Try to limit milling to .030. That will net a 65cc chamber. As far as PTV clearance, measure it.
Old 04-07-2009, 09:15 AM
BlackTA96's Avatar
So what would be a ballpark CR with a 65cc chamber and a flat top piston.
Old 04-07-2009, 09:36 AM
BlackTA96's Avatar
I come up with about 10.8 static.
Im not sure how to come up with dynamic
would 10.8 be suitable to run on pump gas??
sorry for the dumb questions...
Quick Reply: How much can you mill 317s...
