Conversions & Hybrids - Is BCM needed to run VATS on 99 T/A harness/PCM?
kst8engineer
04-07-2009, 08:46 AM
In my swap, I'm using the engine/harness/PCM from a '99 T/A. For a small amount of added security, I'd like to leave VATS in the PCM and run a VATS bypass box that could be removed for security.
To do this, will I need to isntall the body control module (BCM), or can it be done without that?
Thanks
69 Ghost
04-07-2009, 09:11 AM
I don't think so. I was looking into the BCM also and the VATS system talks to the BCM. It also is the gateway to the passkey -the resistor in the key. You can bypass it and put in a kill switch though and the car will not even turn over.
kst8engineer
04-07-2009, 10:31 AM
So if VATS can be used without the BCM, what PCM terminal to I need to supply with a signal to make VATS happy? Does the VATS bypass box just need to feed into this PCM terminal and not even use the BCM?
69LT1Bird
04-07-2009, 11:07 AM
Do you have the steering column? An aftermarket security system may be less hassle.
ls1nova71
04-07-2009, 12:10 PM
You don't need the BCM. The VATS bypass box will have three wires, a ground, ignition on power, and the third wire goes to the PCM, (dark blue wire, #30 on the red PCM connector). I put a 3 terminal plug on mine so I could remove it too, been working for years.
kst8engineer
04-07-2009, 12:41 PM
Great, thanks for the detailed response!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
