Overdrive Tranny Slippage. Is this Normal?
I can rebuild a motor all day long, but not too educated on transmissions. Hear me out please.
I have a 2001 Trans Am WS6 auto. The car has the stock motor and long tube headers, tsp cat back exhaust, and minor suspension bolt ons. Not to long ago I changed the transmission filter and fluid. The car is around 64k on the odometer. I've noticed two things that started around the time I changed the filter.
1 - When I am in overdrive cruising the tranny will slip slightly when I ease on the gas. It doesn't do it or isn't noticeable if I get on the gas hard. Is this a vacuum related deal with the tranny filter pick up tube?
The car does not do this in 1st, 2nd, or 3rd gear settings. Only in Driver.
2 - Car sounds great when in park or neutral, but when it is put into drive or reverse it almost sounds like there is a clicking or knocking coming from the converter area. It is very hard to hear when under the car, but noticeable in the car and echoed off the curb.
I have HP Tuners if anyone has tips for the tranny?
Is there anything I can do/tune on the tranny to adjust the "unlocking"? And what are the chances the flex plate is cracked on a stock tranny/motor that to my knowledge has never been removed? I am the second owner of the car. The first was female driven.
try laying your foot on the brake lightly while cruisin on flat ground, say around 50 or so, see if the rpm's jump up a little-that would be your converter unlocking, does the same thing as getting on the throttle-the throttle postion switch is designed to unlock the converter to allow the engine to apply more torq for accelration, acting like a normal non locking converter-try and imagine a 4 sp man trans, at a lower speed, step on the gas, kind of a dog unless you downshifted to 3rd
sometimes the PCM can be tuned to allow more % of throttle to keep the converter locked up, or have the speed adjusted to lock up sooner/later
