Lifter Q's
Lifter Q's
well I started up the new motor tonight, and noticed some sound coming from under the valve cover. figured maybe had to recheck my valve lash so oh well. upon pulling the valve cover I realized every rocker except the very back one was bone dry. fired the car up and looked like only the back rocker was oiling at all and it was gushing out pretty healthily.
car has 60~psi of oil pressure on cold start up and I'm running the LS7 lifters. just wondering if anyone believe the lifters are the culprit, since I believe I've heard of it happening to people before.
So, you started a new motor (new bearings, etc.) without priming the oil system, is that right?
Not good at all. Like shoe said, you use a priming tool attached to a drill to pump oil through the oil gallies and out of the bearing clearances. This pre-lubes all of the moving parts to prevent metal-to-metal on startup. It inserts in place of the oil pump stub drive and engages the pump drive shaft. Spin the pump until you see oil pressure (I used a gauge inserted into the factory pressure sender). You should see pressure pretty shortly, but it will take longer for the oil to build and pump up through the lifters and pushrods.
I wouldn't worry so much about the lifters and pushrods - I'd be more concerned about the rest of your bearings.
