Anyone install a muffler on their STS turbo?
Has anyone done anything to quite down their car? I removed the cats and now my car has this drone to it. It's partly because it's a stalled auto so when cruising the rpm stays about the same while shifting thru the gears under light throttle.
I currently have a Borla XR-1 oval, per the recommendation of a tuner. I don't like the way it fits (it is too wide) and would not recommend it to anyone else. But I did like the sound a lot better.
I have a Moroso spiral flow sitting in the box which will be installed asa the new engine is installed. I am certain it will sound worlds better than the stock STS no-muffler approach. Will put a Borla turndown tip on it asa it is available from Summit.
