Question about Oil level in my 383
Old 04-08-2009, 01:54 PM
Greenfire's Avatar
Default Question about Oil level in my 383
I have a forged 383 LT4. Usually these engines take 5-1/2 quarts of oil, well we changed the oil b/c we are still breaking the engine in and added 4 quarts and on the dip stick its reading about a quarter of a inch over the normal oil range? The dip stick has not been cut that we know of. I'm not sure why the reading is off and no we have not been running the engine on 4 quarts of oil. I just don't get why the stick is reading soooo high?
Any thoughts?
Old 04-08-2009, 01:57 PM
ss.slp.ls1's Avatar
Any thoughts?
So stock pan? Level location, engine off, after sitting for a few mins? You might not have drained the pan completely.
Old 04-08-2009, 02:51 PM
My95Z's Avatar
Still isn't drained completely, did you change the filter, they hold about a quart in most cases.
Old 04-08-2009, 06:02 PM
Greenfire's Avatar
Yes we emptied the filter and didn't put any oil in the filter. Stock pan and on level ground.
Old 04-08-2009, 11:40 PM
Chevyguy358's Avatar
this may be a stretch but perhaps the 3.75 stroke crank takes up extra volume and therefore reads a bit high
Old 04-08-2009, 11:46 PM
gold98Z28's Avatar
if you havent stated it and the filter is not full then......
Old 04-09-2009, 12:03 AM
o yea I shoulda caught that
Old 04-09-2009, 12:54 AM
1slo_camaro's Avatar
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
well i would throw in 5 quarts anyways. i had that problem before. my dipstick read wrong. but i just threwn in 5 qts. cause thats what i knew was what my SBC used. just my .02
Old 04-09-2009, 04:43 AM
Village Troll
SS RRR's Avatar
The crank is not submersed in oil. If that were to happen it would cause very bad things.
Old 04-09-2009, 07:10 AM
DAVE00's Avatar
+1 - Even with a stroker and the stock pan the crank or rods do not sit in the oil - can you say whipped cream if they did!!! I never go by my dipstick anymore as my canton pan is deeper then it reads. If you drained it then measure out how much came out - fill the old quart bottles - but go with your gut and top it off with the 5th qt and then check it again after it warms up.
Old 04-09-2009, 08:28 AM
aboatguy's Avatar
+1
Start it, run for a couple of seconds, shut it down
let it sit for a few minutes
check your oil level it should have dropped once the filter filled with oil
Old 04-09-2009, 08:41 PM
Greenfire's Avatar
Ok tomorrow we will start it and let then let it sit. Thanks for the advice I'll let you know how it goes! Hubby just told me he put the filter on empty and didn't start it.
Old 04-10-2009, 12:08 AM
tylert14's Avatar
Maybe good practice to pull a PCM or fuel pump fuse and crank it til you see oil pressure on the gauge then fire it up if there's no oil in the filter... Just my .02 cents.
Old 04-12-2009, 05:28 PM
Greenfire's Avatar
oil filter is full and it's still reading high after running for about 30 sec and shut down. I usually put about 5 quarts of oil in it depending on how it reads. i'm stumped.
Old 04-12-2009, 06:40 PM
Village Troll
SS RRR's Avatar
Next possible step is to buy a mechanical oil gauge, set it up, take a few WOT blasts to see if you are experiencing windage. If not then I'd forget about it.
Old 04-12-2009, 06:48 PM
RamAir95TA's Avatar
I would completely verify that your dipstick length is correct.
Old 04-12-2009, 08:05 PM
gold98Z28's Avatar
if it has a stock pan, and you put a new filter on, then put five qts in and forget about it. make a new mark on the stick acordingly
Old 04-14-2009, 07:02 PM
Greenfire's Avatar
Well well upon further investigation looks like the Oil pan itself is bent. Looks like some dumb **** tried to jack up on the oil pan possibly the person that did my engine build/ install. I'm not about blaming or complanin at this point. I'm just ordering a new oil pan and getting the **** fixed and callin it a day. Guess it's a good thing i got a aftermarket K-member installed while the engine was being built. Might make the job a lil easier.
Thanks all for your help. I feel like a dumbass that I didn't notice that sooner.
Old 04-14-2009, 07:08 PM
ss.slp.ls1's Avatar
Glad you noticed before any engine damage possible from that could have occurred.
Old 04-15-2009, 11:44 AM
BALLSS's Avatar
If the bottom of the pan is smashed in that far due to jacking after the build....it most likely bottomed out on the oil pick up....confirm it is not bent or if welded on did not crack the weld
also if the windage tray is not on...put it on. Many 383 builds don't because of clearance issues...which are EASILY solved by putting in a washer (1/8") between main stud bolt and windage tray. Miloden also makes extended stud bolts or you can use your stock ones
Attached Thumbnails Question about Oil level in my 383-g383-windage-tray.jpg
