exhaust cutout switch to fit in ASR blank?
Old 04-08-2009, 04:06 PM
cdn99ss's Avatar
Default exhaust cutout switch to fit in ASR blank?
Has anyone found a momentary switch that will fit in the dash blank next to the Fog lamps? I have done a couple of searches on the forum and seen some neat solutions, but most will not work for me. My satellite radio blocks off the option of a convertible switch or lighter location. I have aftermarket seats, so I can not mount it near the stock seat controls. The ashtray solution is possible, but I would prefer to keep my parking change there! I could drill and mount somewhere on the lower console, but that can be either hard to see or reach. That ASR blank looks like a perfect location, but I want something that will blend in and not look bubba. Will a power window switch fit in that spot? Thanks in advance for any advise.
Old 04-08-2009, 06:13 PM
NJ 2002 Z28's Avatar
You can use the convertible switch in the ASR blank spot that is how I have mine set up..
Old 04-08-2009, 07:26 PM
cdn99ss's Avatar
Brilliant! Thanks for the definitive answer.
Old 04-08-2009, 08:09 PM
Lucky you I still have what I used to do it bookmarked..
This will pretty much clarify everything you need to do..
https://ls1tech.com/forums/stereo-el...-question.html
Old 04-08-2009, 08:41 PM
GMRL's Avatar
Another option is to use the hole for the cig lighter in front of the shifter.
Youll still have the one in front of the e brake.
Or vice versa.
Old 04-09-2009, 12:02 AM
Moderator
jimmyblue's Avatar
https://ls1tech.com/forums/generatio...-approach.html
Quick Reply: exhaust cutout switch to fit in ASR blank?
