Clutch fluid change
Clutch fluid change
I need to change my fluid what is the best way just try to pump it all out with the bleeder open then add new and bleed it? Is there a better way. I want all the old bad fluid out and all new in. Also how much should I buy or how much will I waste doing this project.
Also when you pay someone to put in a new clutch and master cyl is it common practice to change the fluid as a mechaninc?
A better way? Yeah buy a Motive power bleeder for like 50-60 bucks. It makes life so much easier when bleeding your clutch and your brakes, I promise. Makes it a 1 person job and it's quick.
Internet Mechanic
I have used Valvoline Syn Power as well as non Syn DOT4 with great success. If you want to be very sure all has been run through you could get a big bottle and gravity bleed it. If you do it with 2 and have one crack the bleeder and do the pedal, then a small bottle is fine.
Fluid swaps help but if your pedal is crashing, or sticking, then you may have a mechanical issue.
