bypass valve location
Old 04-08-2009, 09:52 PM
baylove's Avatar
Default bypass valve location
hey guys im wondering does it matter where i put the bypass valve ?? im installing p1sc and a front mount intercooler on a lt1 camaro
Old 04-08-2009, 10:05 PM
Super Slow SS's Avatar
Idk how important it is on fbodies as I dont know anyone that has one, but I have seen it help to mount it pre intercooler,
Old 04-08-2009, 10:10 PM
conan's Avatar
I was told to put it before the intercoolers so the only time hot air was going through them is when you want it in the engine. No heat soak of the cooler. Are you going with the twin or a front mount intercooler?
http://mycarpics.shutterfly.com/235
http://mycarpics.shutterfly.com/219
http://mycarpics.shutterfly.com/226
Old 04-09-2009, 10:13 AM
LS1RedZ's Avatar
here is mine man.
Old 04-09-2009, 11:08 AM
baylove's Avatar
single front mount intecooler with a vortech bypass valve
Old 04-09-2009, 04:39 PM
baylove's Avatar
this guy has his here
and this guy has his here
will both locations work ??? i was thinking of doing mine like the first picture
Old 04-09-2009, 05:47 PM
boosted-lt1's Avatar
Yup. No point to push hot compressed air through an intercooler to just dump it afterwards. Blow off the discharge before the intercooler and don't run it back to the compressor inlet like some off the shelf kits do - just vent it to the atmosphere.
-Scott.
Old 04-09-2009, 07:43 PM
BlkHwk's Avatar
-Scott.
I wonder how much difference it really makes. Next time the weather is nice, and I take my car for a spin I'll log my IAT's and compare to ambient. I personally don't feel there would be a significant difference, but testing would tell the tale. I have the twins with the original bypass. I've been looking into this recently myself. Trying to figure out where would be the best place to mount a larger bypass. If you want to go pre intercoolers with the twin setup the only option would be to make another tube after the supercharger and install it there (see pic). The problem with that would be a dust storm if the roads are dirty at all ,dirt all over the engine bay, been there done that don't wanna do it again. I've been considering mounting my new bypass (still haven't decided what I want to get yet), where the maf used to be.
Old 04-09-2009, 07:46 PM
BlkHwk's Avatar
Nicely done BTW
Old 04-09-2009, 08:11 PM
BlkHwk,
Maybe you could run a hose from the outlet of the BPV and position it so it wouldn't blow a bunch of crap under the car.
I just wouldn't want to push any more hot air through an intercooler than necessary.
-Scott
Old 04-09-2009, 08:58 PM
conan's Avatar
Originally Posted by BlkHwk
Nicely done BTW
Thanks man. I had my bypass facing the gound and it did make a dust mess so I just rotated it on the flange so it points up to the washer fluid tank, no more dust cloud. Also from what SDCE told me when I bought the kit the smaller twin intercoolers are the worst for the heat soak compaired to the large front mount. When I switch to a front mount I still will try to mount the bypass before the cooler.
Old 04-10-2009, 08:07 AM
BlkHwk's Avatar
BlkHwk,
-Scott
The pic I posted is one I took off the EPP site. I currently have mine vented to atmosphere pointed up. That works really good. The only downside to doing it this way is you have to be very careful while washing the car.
Old 04-10-2009, 09:33 AM
TiAL's Avatar
put it where the vac line is going to be the shortest.
Old 04-10-2009, 10:19 AM
baylove's Avatar
Old 04-10-2009, 10:29 AM
LS1RedZ's Avatar
I was going off EPP's racecar. They have their race valve mounted up where mine is too. I have seen quite a few cars with theirs mounted after the intercooler. Will it make that big of a difference?
Old 04-10-2009, 12:19 PM
BlkHwk's Avatar
Originally Posted by baylove
Sorry Bud, I was just raising some questions pertaining to the topic title and the advantage and disadvantages of different mounting locatations. IE pre and post intercoolers etc.
Old 04-10-2009, 03:04 PM
baylove's Avatar
lol nothing personal we all on the same page good info tho
Old 04-10-2009, 03:54 PM
Jimmy P's Avatar
I originally bought one of the "off the shelf" intercooler kits and they had it plumpbed after the intercooler. When I got rid of it and had a shop custom make me a new intercooler setup, I requested that they mount it before the intercooler.
Old 04-11-2009, 10:50 AM
AFASTYZFR1's Avatar
but if you mount it closer to the tb wont the boost hit a little earlier.....? I have meth so I am not worried about iat's
Quick Reply: bypass valve location
