AI Cam Only Track Time...Finally
Well i finally got some clean passes down the new concord 1/4 mile dragway (ZMax). I'm running on street tires at 25 psi, so hooking was not an option, which after breaking one 10 bolt i cant say i was too upset, plus the penske's dont really like the drag strip too much anywho...
Best run:
60' 2.172
1/8 E/T 8.483
1/8 MPH 88.76
1/4 E/T 12.859
1/4 MPH 113.48
I was very pleased with my mph, if i could get to a better altitude im thinking 114 won't be too hard of a goal. E/T was eh, but with a 2.172 60' im pleased. Overall a good night, car was very consistent, out of 4 runs the lowest MPH which happened to be my first run was a 112.98 so .5 MPH variance in 4 runs and E/T's were within .1 of each other on all 4 (which means i consistently sucked on the launch ). Cam loves the top end though, i love it.
Best run:
60' 2.172
1/8 E/T 8.483
1/8 MPH 88.76
1/4 E/T 12.859
1/4 MPH 113.48
I think the DA was about 1200 from what i heard, the actual elevation was 800ft. The cam is the older version of the cam above, its a 224/234 .563/.577 @ 110 LSA, im very pleased, i'd like to throw a 12 bolt in it and when i do that i'll actually put a good tire on it, my KDW's are a great tire around the corners, but absolutely worthless off a dead stop.
Ran almost identical in my cc306 cam-only car on street tires. Its really moving considering how much smaller in duration the cam is, a little more seat time and you should see some 12.1-12.2 on sticky tires. Looks like a good cam-only combo, I imagine you shift around 6500 too.
