Just dropped my motor in but still 8inch wheel gap!!!!
Old 10-25-2003, 05:50 PM
andy98Z's Avatar
Default Just dropped my motor in but still 8inch wheel gap!!!!
I replaced the K member with a a BMR....just got the new motor so I dropped it in thinking the wheel well gap should drop back close to normal. DIDNT MOVE!!!! Could my shocks be frozen from the car sitting so long with no weight?
Old 10-26-2003, 01:16 AM
trackbird's Avatar
It is more likley that the suspension is on a bind right now. All you need to do is roll the car back and fourth a few feet and the wheels whould return to the normal position. Then you will see the actual ride height of the car. After you roll it back a few feet, bounce the front of the car a few times then roll it back.
Good luck!
Old 11-01-2003, 06:21 PM
andy98Z's Avatar
Drove the car around still extra space in the wells, i loosened the a-arm connections, and loaded the front end, even jumped up and down on the car, tightened them back up, still too much space, what can it be?
Old 11-01-2003, 10:46 PM
mitchntx's Avatar
Another thumbs up for BMR!
Old 11-02-2003, 03:52 PM
onehardmaro's Avatar
Could you possibly post a picture? Is the suspension traveling at all then returning to that height or does it just stay at that height.
Old 11-04-2003, 07:43 AM
andy98Z's Avatar
No it sits like that all the time. Ill take a pic and post it. I do have 150lbs off the front of the car.
Old 11-04-2003, 07:45 AM
mitchntx's Avatar
So, if you sit on the nose, does the gap go away?
Old 11-04-2003, 01:16 PM
CHRISPY's Avatar
It will sit over an inch higher after removing all that weight.
Cheers,
Chris
Quick Reply: Just dropped my motor in but still 8inch wheel gap!!!!
