First time at the track... What do you think?
Old 04-09-2009, 01:07 PM
landonew's Avatar
Default First time at the track... What do you think?
1/8 mile track unfortunately
7.82 @ 88mph, 1.91 60ft
Unfortunately, I couldn't get a nitous pass in because the bottle had a bad seal.
Do yall think the car has more left (with a better driver)? I was stoked to get into the 7s.
I think she needs to lose some weight. The AC might be coming out (doesn't work anyway).
Old 04-09-2009, 01:24 PM
COMNBYU's Avatar
What's the elevation & what were the conditions???
With 450 to the wheels you should be able to do a little better than that...
Jon
Old 04-09-2009, 01:29 PM
98CamZ28's Avatar
With a good 60ft and that power, i'd imagine 7.0's shouldn't be too hard depending on your weight, hell, i wouldn't be surprised to see runs in the 6.x's
Old 04-09-2009, 01:50 PM
landonew's Avatar
elevation was 600ft.
Temp was in the 72 degrees with around 40% humidity.
Car is full weight ++. Has a sound system and 9" rear end. Also has about 30 lbs of nitrous accessories (15lb bottle, nano kit, wiring ext.) as well as sub-frame connectors, LCAs, Panhard bar, and Denny's nitrous ready DS.
In other words, it is probably close to 4,000#s with me in it (maybe a bit more).
Old 04-09-2009, 03:14 PM
LM97Z's Avatar
I'm sure you'll get into the 7.5-7.6 range with 1.7s on the 60ft., you definetly won't see 6s NA, but on the bottle you should easy. Still thats cookin @ that weight & fully dressed
Old 04-10-2009, 04:44 AM
99_Z28's Avatar
The car definitly needs to go on a diet. I ran a 7.7 @ 89.8 on junk parts.
Old 04-10-2009, 12:18 PM
landonew's Avatar
m6 v. A4.... But I agree with you on the diet part.
Old 04-10-2009, 11:24 PM
s346k's Avatar
wtf? the car trapped 88 with 452 whp @ a 700' elevation? something is definately wrong. the weight might be accounting for 2-3 mph at most vs. a "normal" fbody without all of the crap in it.
my bolt on automatic car went 7.6 @ 88 at 2800' with a 3700lb raceweight. hell, my wife's 99 m6 ta with a lid and weld in flowmaster only, stock everything else...went 8.3 @ 88. something is f'd up, you have very good parts, that car should easily be going low 7s on a decent tire. how was the transmission shifting? you're losing like 85whp somewhere from your sig to the racetrack...
Old 04-11-2009, 09:50 PM
landonew's Avatar
The transmission is fine from 1st-2nd... However, it sticks from 3rd-4th... I need a new clutch.
I am leaning toward th400 instead of replacing the clutch. The ls7 was fine until I hit it with the N2O..... Has never been the same since.
Have replaced the hydrolics... I am thinking it is the pressure plate.
Anyhow, I figured the car had some left. Didn't know it was 6/7 tenths though.
Old 04-13-2009, 07:23 AM
s346k's Avatar
ah. perhaps the trans is the problem. i am unaware of how "well" you drive, but even a poor driver with power like that would be quicker. i'm a fan of automagics anyway, i say go with a th350 and 4500 stall, then call it a day. say hello to 7.teens and a required rollcage.
Old 04-13-2009, 08:06 AM
holley505's Avatar
I think your car should be a little faster... thats a low 12s / High 11s 1/4 mile pass... but weigh would play into that as well as the 1.9 60ft.
I think mid 7 N/A and on the gas... in the 6s... maybe mid 6s if you can hook up.
Old 04-14-2009, 04:26 PM
landonew's Avatar
Thanks for the input. I am thinking I will go with a powerglide after I take 500-600#s out of the car (all the !weight mods ... plus bogarts, minitub, kirkeys, rack-and-pinion, drag brakes, maybe even a pin-on-hood. I have alot of research to do before I take the next step.
Quick Reply: First time at the track... What do you think?
