Bad seal on Bottle
Bad seal on Bottle
I have a 15lb nitrous bottle with a bad seal. Who sells replacement seals and does anyone sell a superior seal that is less likely to fail. Is frusterating to get to the track only to find out you can't spray your car.
Sorry to be so vague.
It is leaking where the valve meets the bottle. The valve itself is fine... its the circular seal where the valve connects to the bottle.
tightening the valve did NOT do the trick, so it needs a new seal.
