Flash high beams?
Old 04-09-2009, 04:13 PM
starfishy's Avatar
Default Flash high beams?
Most cars I have driven can flash their high beams with or without the lights on and without the high beams permanently engaging (e.g. Ford: pull turn signal stalk to flash, push it to engage high beams). The Camaro does not seem to be able to do that.
Am I missing something and the Camaro has this feature?
If not, can it be retrofitted? (Maybe use the turn signal stalk from a different model)
Thanks
Christian
Old 04-10-2009, 02:32 AM
starfishy's Avatar
I found two articles on the subject (install a '94+ Caddy Fleetwood dimmer switch):
Original article
Version with pictures based on article above
I'll try that.
