tunercats help
Old 04-09-2009, 11:13 PM
dan catalyst's Avatar
Default tunercats help
i just got my cam heads and headers on, and i was wondering if anyone could help me with getting the tune close enough to drive to the dyno.anyone care to post or pm me a screen shot of there timing and ect tables so i can fix my tune close enough to drive?ive used tunercats a couple times, but im not that good at it.i know i need a higher rev limiter, more timing esp. down low,but what else do i need to do?
Old 04-10-2009, 01:43 AM
7.0 camaro's Avatar
dont know if this will help. but it runs good in my car. run at your own risk haha. i dont have o2 sensors.
map table
main timing
extended spark
Old 04-14-2009, 01:16 PM
kenscivic's Avatar
hey breakout, mr. im a tuner now lol... he knows his stuff.. he had a bad tune in his car and he went from 85 mph in the 1/8 to 88 mph with a smooth looking a/f ratio!!
Old 04-14-2009, 01:33 PM
MTBSully's Avatar
anyone running tunercats with vista? Any tips to installing it?
Old 04-14-2009, 02:01 PM
Low N Slow's Avatar
I got Tunercats and Datamaster to work by going into control panel, then programs, then Use an older program with this version of windows. The compatibility wizard comes up, pick Tunercats or Datamaster from the list of programs. Pick Windows XP from the first list that comes up. On the next screen check these 3 boxes: Disable visual themes, Disable desktop compositions, Disable dispay scaling. On the next screen check run the program as administator.
Tunercats, Datamaster and Wideband Commander work now using this method.
I hope this helps you.
Quick Reply: tunercats help
