Stereo & Electronics - Using SLP's Fan control Switch w/ Emblem-Pro Swicth Plate
Nightrydass
04-10-2009, 12:06 PM
I'm going to order a switch plate from Emblem Pros, and one of the switches will be for my SLP Fan Control. Emblem Pro has the switch for it, but i wasn't sure how to "migrate" SLP's controller with Emblem-Pro's switch; do i just just the switch off othe SLP controller and hookup the one from Emblem-Pros?
slow
04-10-2009, 12:18 PM
to keep the wiring how slp did it, you will need a DPDT switch, center off. I am unsure if they offer that switch.
if they do, the wiring is easy. 5 wires, 3 jumpered together, and 2 to the other 2 wires.
Ryan
Nightrydass
04-10-2009, 12:56 PM
they offer a 3-pin/3 postion switch; is that what i want?
"...3-Position switches are used for variable speed cooling fans. It will be up to you to supply the proper relay. This switch is a 3-pin switch...."
slow
04-17-2009, 08:06 AM
you will need to run 2 relays to keep with the slp method of low speed the J wire is grounded, and in high speed the H and J wires are grounded. (of the 10 pin connector)
Ryan
Nightrydass
04-17-2009, 09:02 AM
unless i can get a wireing diagram of the relays and such, i'm prob just going to relocate the SLP switch and keep it as is. lol
transambandit
04-17-2009, 12:31 PM
here is what i have done with mine until i can figure something else out, you can see there is a little gap on each side because the SLP fan cover is square and the emblem pro is circle.
slayer_taunu
01-20-2010, 09:36 AM
nightrydass, did you ever figure this wiring out? or did you just do like transambandit did?
my slp fan switch is round, and doesnt look like it will fit in the hole in the emblempros switch plate.
