TB Bypass & Y-Pipe Hanger Questions.
Old 04-10-2009, 12:49 PM
Nightrydass's Avatar
Question TB Bypass & Y-Pipe Hanger Questions.
sry, the search function doesn't seem to be working...
My first question is regarding the TB Bypass; what size vac hose is it, and how long of a hose should i buy?
My 2nd question is in regards to that y-pipe bumpstop hanger one of our sponsers sells; how does that work? My SLP y-pipe hits my floor board and it is getting annoying. My concern is preventing the exhaust from not being able to flex at all; somehting has to give, somewhere. Does anyone use it, is it good to have?
Old 04-10-2009, 01:46 PM
LS1nterceptor's Avatar
All I did was buy one of these:
http://www.lowes.com/lowes/lkn?actio...PK1&lpage=none
And use the existing hose. I just disconnected both ends, stuck that in the middle, and used the existing hose clamps to tighten it. My factory hoses were long enough.
But to answer your question I believe it's 3/8 hose.
Old 04-10-2009, 02:15 PM
Thank you!
#1 is down; anyone have any info on my 2nd question?
Old 04-10-2009, 03:35 PM
lilpb1's Avatar
Thank you!
I would like to know too because it makes it sound like my tranny is about to fall off!!!!
Old 04-10-2009, 03:38 PM
jsteele90's Avatar
replace your motor mounts
Old 04-10-2009, 05:53 PM
Caribe's Avatar
The y-pipe bumpstop is mounted in an existing hole that is used for your heatshield. It uses a rubber bumper to allow the y-pipe to move a little without hitting the bottom of the floorboard. The other end attaches around the y-pipe.
Old 04-11-2009, 09:48 AM
Nice, how many do i need; just one?
Old 04-11-2009, 07:49 PM
Caribe's Avatar
Just one. Install it under the driver's seat. I'll see if I can get a pic of mine today.
Old 04-11-2009, 09:27 PM
max_ta's Avatar
I would like to see it too
Old 04-12-2009, 12:03 AM
Caribe's Avatar
Here you guys go.
Quick Reply: TB Bypass & Y-Pipe Hanger Questions.
