Lets see those Custom 3rd Gen Fbody/LSx Swap fuel systems!!!
Old 04-10-2009, 03:35 PM
cabech984's Avatar
Default Lets see those Custom 3rd Gen Fbody/LSx Swap fuel systems!!!
Im curious how everyone runs their fuel lines and stuff underhood for their LSx swapped third gen fbodies!! I wanna see where everyone places their fuel regulators and routes lines, etc.
Post Pics!!!!
Old 04-10-2009, 03:56 PM
NemeSS's Avatar
mine is carb, so im using aeromotive efi pump to carb pressure fpr
with -8 return. no pics right now
Old 04-10-2009, 05:47 PM
Jaysz28's Avatar
Here ya go
-jason
Old 04-11-2009, 02:46 PM
cabech984's Avatar
Jayz28,
Nice setup!! I got the same regulator and am connecting it to the same fuel rail as you. Did you cut your factory hard lines shorter or something? Mine turn 90 degrees and go straight up. Also, dont you need a vacuum line ran to the regulator to reference manifold vacuum??
Also like the K&N Setup, what vehicle was that designed for??
More pics!!!
Old 04-11-2009, 10:57 PM
Jaysz28's Avatar
ls1's didn't use a vacuum reference regulator. I just set it to 58 PSI and left it alone
k&n setup is from an '04 gto IIRC
factory lines are not cut. I just bought the adapters from summit and found stuff to make it work.
-jason
Quick Reply: Lets see those Custom 3rd Gen Fbody/LSx Swap fuel systems!!!
