Nitrous on stock clutch.
How would a stock clutch handle a 100 to 125 shot. My car is a 04 GTO with about 50,000 miles. I would not be spraying in first.
Should the stock clutch be ok for awhile?
that depends on how you are releasing the pedal, quick release is probably the best method on the stock clutch. if you try to slip the clutch, it's gonna wear out faster.
