Cam?
Old 04-10-2009, 05:53 PM
Kitcarguy's Avatar
Default Cam?
I have a 96 Lt1 motor that I'm in the process of rebuilding and the cam doesn't appear stock. It has 864 stamped on the end and GMPT-BC-17-705 or7035 in between the lobes on one end, anyone know what this cam is?
Old 04-10-2009, 06:00 PM
ss.slp.ls1's Avatar
Does the motor have stock springs, rockers, etc?
Old 04-10-2009, 06:06 PM
Kitcarguy's Avatar
Not really sure I put them on a spring tester and they maxed out at about 295 lbs,the springs look a little beefy compared to stockers.
Old 04-10-2009, 06:11 PM
ss.slp.ls1's Avatar
Hate to burst your bubble...that's a stock '95-'97 cam. The 705 just means it has the longer dowel pin.
Old 04-10-2009, 06:12 PM
Kitcarguy's Avatar
No problem, just means I need to order what I've been wanting for the build. Thanks for the info!
Old 04-10-2009, 06:14 PM
ss.slp.ls1's Avatar
Which is...
Old 04-10-2009, 06:18 PM
Kitcarguy's Avatar
XFI 466, I'm basically building a daily driver with ported heads,headers,intake,RR'S,ewp,etc
Old 04-10-2009, 06:22 PM
ss.slp.ls1's Avatar
Are you sure you have the right cam number?
Old 04-10-2009, 06:25 PM
Kitcarguy's Avatar
Well it was a Comp Cams, 218/224 .570/.565 113lsa, But I'll probably be looking at something else now.
Old 04-10-2009, 06:29 PM
ss.slp.ls1's Avatar
You want this grind number:
268XFI HR13
I'd go bigger if I were you. I DD my CC503 and I love it.
Take a look at the 276HR-12 (CC503)
224/230 .503/.510 112
Old 04-10-2009, 06:34 PM
Kitcarguy's Avatar
Cool appreciate the info, build pics soon!
Old 04-10-2009, 07:32 PM
StealthFormula's Avatar
That XFI cam your looking at would be a fantastic cam for a DD like your planning to build. Honestly though I would step up to the cc503 if you want to run an off-the-shelf. The cc503 is great in daily drivers (drove it to school an hour each way) and will not only sound noticibly choppier (if thats what you want) but make a solid 10-15hp/tq over the 466. Plus the cc503 would be pretty nice with ported heads.
Old 04-10-2009, 10:46 PM
myltwon's Avatar
if you're porting the heads I'd look into a custom LE cam, only like 30-40 bucks more shipped than a comp cam + shipping
Old 04-11-2009, 02:00 AM
marc97taws6's Avatar
I'd recommend the 224/230 also for a DD
Hear they make good numbers yet still drive good as a DD
Old 04-11-2009, 08:57 AM
ryleag's Avatar
I have the Comp 230/236. I love the top end, definitly kicks ***, but it's a dog down low. If I could switch things up I would have went a little bit lower in duration.
Old 04-11-2009, 11:34 AM
ss.slp.ls1's Avatar
You probably didn't optimize your set up...what stall (if A4) and what gear are you running?
Quick Reply: Cam?
