Rubbing/Clunking Noise !?!?
symptoms: 1998 T/A makes a rubbing/clunking noise everytime i take off AFTER A PRETTY HARD STOP like at a stop sign or a red light. when i stop something appears to be shifting forward (i can't feel it, i'm only assuming). then, under acceleration i can actually HEAR/FEEL something rubbing underneath. like metal is rubbing and something is "sliding back" underneath the car.
at first thought i thought it was the tranny mount(s) but after doing quite a bit of research on here for a few days and driving the car pretty much daily for the last 2 weeks i have narrowed it down to the u-joints.
i DO NOT think the rear end or the actual transmission is taking a **** on me, so the u-joints would have to be what's doing the rubbing/clunking.
i read all 3 of these threads and i just need a bit more advice just to see if i'm on the right track. jeeez, it's late and i'm searching for this crap, HAHA !!!!
https://ls1tech.com/forums/general-m...rm-instal.html
https://ls1tech.com/forums/general-m...ment-help.html
https://ls1tech.com/forums/general-m...oints-out.html
thanks for your help guys.
im also gettin that kind of noise. So i feel ya there. Cept, mine is not rubbing, i just hear a clunk type noise. It sounds like its coming from the right rear of the car. i cant figure it out either! I will be monitoring this thread to see what you all say.
Dave
Dave
to be honest with you, i feel it in the rear driver side, but i'm only guessing that even the control arm would rub/clunk so much that it almost appears as if it's right underneath your feet.
i dropped the car about 2 weeks ago and we checked the rear control arms. actually, we just moved them and visually inspected the bushings. control arms/bushings appear to be fine.
but if i had to guess i'd say the noise is about 80% in the rear.
