Steering column/link/knuckle question?
I just installed some headers and have some clearance issues with my steering knuckle/link hitting on one of the primaries. Does anyone know if I can loosen the steering column enough to get more angle out of it on the engine bay side to clear the primary before I take a hammer to the header tube? Basically, can I angle the steering shaft on the engine side more toward the fender away from the engine by loosening something in the column bolts and pushing/re-tightening?
Ebay headers from Pit Stop Tuning...LPP clones basically. It is not a whole lot, but enough to make life difficult. China puts an angle off just a little up top=big trouble down the pipe :-( They are great quality, just having some fitment issues. I would say the primary needs to be flattened about 1/8" maybe. Not a whole lot, just slightly flattened on the straight part of the run...and only because it is stepped up right there.
All in all though, for $450 shipped with the "y" included, it was well worth the money. I picked up 30 rwhp on the dyno with the exhaust alone...not to mention the mean sound it has now :-)
That was my next question...can I grind off the excess metal on the steering knuckle to clear?It is on the u-joint part though and I don't want to take away strength from my steering components if you know what I mean. Or are they grinding something up stream on the column to give the clearance/movement necessary to get the right angle in the engine bay?
Thanks...pictures would have helped on my part, but hopefully everyone got it based on the description of where I was having the issue. I'm just always hesitant to cut away material from a steering component unless there is plenty/overkill material there. I also don't want to hammer in my headers.
Any thoughts on stock vs poly mounts? I plan on building the top end of the motor some, but not surpassing 400 rwhp.
Yea, I've looked into the whole LS1 conversion and I think I will just use the rag joint eliminator and keep the LT1 steering piece. I think once I replace the motor mounts it will help with clearance as well. I finished modifying the primary and the steering clears enough for now until I replace the mounts...which will more than likely clear it the rest of the way. Thanks everyone for the ideas and suggestions.
I do have another issue though...I posted another thread about it...
