Rocker Arm bolts and Loctite?
Old 10-26-2003, 03:16 PM
John02SS's Avatar
Default Rocker Arm bolts and Loctite?
When putting the rockers back on they are torqued to 22 ft lbs with loctite on them. The motor is turned 180 and retorqued to make sure they are 22 ft lbs. My question is how long for the loctite to dry? Is there a chance that the first couple of bolts may be dry by the time you turn the motor over and get back to check them risking breaking the loctite loose? Thanks in advance!
John
Old 10-26-2003, 07:05 PM
Tin Indian's Avatar
I never read in the service manual to use thread locker on the rocker bolts.
Where did you read that?
Old 10-26-2003, 07:07 PM
John02SS's Avatar
JMX's how to page. Couple of different items should have loctite on them.
Old 10-26-2003, 07:14 PM
Tin Indian's Avatar
You won't find that in the service manual
Of course, I can't see that it would hurt anything
Old 10-26-2003, 07:16 PM
John02SS's Avatar
Do you think this is needed?
Old 10-26-2003, 08:15 PM
Scalpel's Avatar
Loctite is not specified in the service manual nor is it needed. Is it ok to use? Sure, but way overkill, IMO.
Old 10-26-2003, 08:27 PM
bigSS's Avatar
Threadlocker is not needed, but it is a good idea to use some RTV.
Old 10-26-2003, 08:34 PM
John02SS's Avatar
What would the advantage be of using RVT on stock heads. I've seen were the ported heads needed some due to the porting going through and the RVT sealing it. I'm not worried about sealing, I just don't want the bolts to come loose.
Also, is using loctite bad on aluminum heads? I was under the impression from a GM mechanic that it was applied when assembled. Thanks for the input guys!
Old 10-26-2003, 08:40 PM
felton316's Avatar
They use loctite or thread sealer due to what John02SS was saying. After porting heads, the rocker arm boss is exposed, and if not sealed it could possibly leak oil through the bolt hole. If you are just torqueing rockers on stock unported heads, then you do not need any loctite or sealant, that's why the service manual does not mention anything.
Old 10-26-2003, 08:46 PM
HumpinSS's Avatar
I didnt see any locktite on my rocker studs when I did my 2000 and I didnt put any back on either
Old 10-26-2003, 09:28 PM
2xLS1's Avatar
I think there is some sort of locker under the head of the bolt from the factory, but not on the threads. I never use any on reassembly either. I do use teflon thread sealer on the intake rocker bolt threads on ported heads.
Old 10-26-2003, 09:31 PM
John02SS's Avatar
Would using a little as suggested in the how to article hurt anything upon removal the next time or just a little over kill. BTW, I like overkill!
Old 11-03-2003, 08:37 AM
John02SS's Avatar
Just wanted to bring this back to the top.
Old 11-03-2003, 08:48 AM
Tin Indian's Avatar
John ...
There is no real answer to this. The service manual does not specify thread locker on rocker arm bolts. If you want to use it, go ahead .. no big deal.
Not much more to say ....
Old 11-03-2003, 11:02 PM
John02SS's Avatar
Does the manual suggest loctite on any bolts involved in a cam swap?
Old 11-04-2003, 12:38 AM
2xLS1's Avatar
I use L/T on the cam sprocket bolts. That's all.
BTW, I just removed the rocker arms on a virgin 00 LS1 and there was red L/T under the head of the bolts. It was obvious.
Old 11-04-2003, 02:57 AM
Jabroni's Avatar
I cannot recall if the manual said anything about it, but the only ones I remember being an issue were the three cam sprocket bolts.
Quick Reply: Rocker Arm bolts and Loctite?
