1985 C4 Corvette LS1, 4L60E Swap update
Old 04-12-2009, 03:41 PM
grind4it's Avatar
Default 1985 C4 Corvette LS1, 4L60E Swap update
Just thought I would post some picture of my LS1/4L60E swap.
I am following the Corvette Enthusiast build as a model for this build. I have modified the engine some:
Stock bottom
Ported 243 Heads with lightweight valves
GM LS7 lifters
234/232 114 cam
LS1 Double roller timing set
Ported LS6 oil pump
LS6 intake
180* Thermostat
Full length headers
Full flow mufflers (no cats)
TCI Street fighter 3200+ stall torque converter
Next step is to start fitting the LS1 in the C4. When I have it in I will post the pictures.
Mark
Attached Thumbnails 1985 C4 Corvette LS1, 4L60E Swap update-post01.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post02.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post03.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post04.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post05.jpg
1985 C4 Corvette LS1, 4L60E Swap update-post06.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post07.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post08.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post09.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post10.jpg
Old 04-12-2009, 03:47 PM
grind4it's Avatar
Default More pictures
More pictures
Attached Thumbnails 1985 C4 Corvette LS1, 4L60E Swap update-post11.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post12.jpg   1985 C4 Corvette LS1, 4L60E Swap update-post13.jpg
Old 04-12-2009, 11:38 PM
SPDMETL's Avatar
Cool swap...I don't think I've ever seen a C4 burnout photo
Old 04-13-2009, 07:47 AM
grind4it's Avatar
When I finish the build I will post a nasty burn out. Have no fear I drive em' like I stole em'
Old 04-13-2009, 11:48 PM
Platinum 2k9's Avatar
oh man do i have a few questions for you!
Did you use the d36 or the d44 rear? also if you used the D36 how much did you have to shorten/lengthen the d-shaft? did you get the mount plates from tran-dapt,AS&M or vetteworks?
I'm working on a similar swap and these are the questions i've had. I'm using the C5 bracketry though( make alt changes easier) and using the Z06 exhaust maniflods so i dont have to cut much. which oil pan are you using? C5 or F-body? are you using the C5 balancer or are you using all f body stuff?
On the harness- are you doing the same thing i am and making the LS1 harness a stand alone( powered off the ecm ign and vats circuits) to keep the digidash or are you going full autometer like Cory from LS2 works?
Old 05-04-2009, 11:07 PM
SPDMETL's Avatar
Done yet ?
Quick Reply: 1985 C4 Corvette LS1, 4L60E Swap update
