Reading timing mark w/ race fuel??? Pros ONLY!
So the car is just a cam only car with a 150 shot. I was running it right off the rail and I was not getting a timing mark.
So I stepped up to a stand alone because I'm going to up the shot, and I put 112 sunoco in the stand alone and 93 in the tank.
The first run I guessed on the fuel pressure and it was fat! But it looked like I was getting a timing mark? But I'm not sure cause the 112 changed the strap color??? 20* timing
So I pulled 2 degrees of timing, and dropped the fuel pressure and here is the result...
Is that not a timing mark? I lost 1 mph from the fat tune up to the 2nd.
Race your car!
That is a timing mark. I like where it is on the 2nd run, but it still looks a little fat to me. I'd take a little more fuel away and leave the timing where you have it on the 2nd run.
Those plugs, you shut the car off at the end of the run and pulled them immediately after yes?
Race your car!
o.k. good. That's what I figured.
The #8 for your use looks about right heat range wise. I's just take one fuel jet away from that, and the plugs will probably look pretty good.
What jetting/system are you using, I know they're all a little differwnt but I'l be able to relate better if I know what parts are being used.
Race your car!
I'm running a Nos plate, the 150 jetting it came with was a 63/44 initially. I've played around with it a bunch and to get the plugs reading right I ended up going to a 65 nitrous jet and a 43 or 42 fuel jet, depending on the weather.
Granted I'm on alot more compression and a bigger motor, differnet heads etc.etc. but that's what I ended up doing to get it right.
Race your car!
Edited mine to reflect your changes
Now knowing that's your 150 jetting... the fuel's a bit lower then mine is. Where is your a/f with the car on motor? I've got my car tuned to about 12.8 to 1, the nitrous fueling lowers the a/f from there (I have never dyno'ed the car on the jug so I am not sure what the actual # is, I just read plugs)
I know mine's still heavy on fuel. Honestly from the supplied jetting (63/44) with the nos plate to what I'm usually running now (65/42) I've picked up .3 and almost 3 mph. My fuel ring is still a good bit heavier then yours, but it's been so consistant I didn't really want to screw with it.
Changing everything before it gets back out so at this point it doesn't matter... but something to think about.
The timing mark is on the ground strap where it changes color (where the rust color stops)
Your at the bend on the last plug I like to run mine closer to the tip of the strap. If you take timing out it will move the mark toward the end , add it and it will move toward he threads.
When you lean it out it will also move the mark because it makes more heat.
awesome. ill try my current setup, without my tuner at the track it kinda sucks because i cant change timing so i get hancuffed so im trying to figure out where to run it prior to going out so i have a better chance at succeeding. we are at 20* in a cam only motor with projected tr6's on 1000...
if i went to a 7 would you still run the same timing... im thinking lower it down to 18 for this track day and just try to adjust jet changes for a 150-200 two stage?
