extra p in PPRND21??
Old 04-13-2009, 10:20 AM
demonpixel's Avatar
Default extra p in PPRND21??
About to install my B&M Hammer shifter on my TH400. I read the instructions but it didn't answer this question: Why does my Hammer shifter console have an extra P, and my stock one only has one P? (I know it stands for Park.) What does the extra P stand for)?
Old 04-13-2009, 11:12 AM
patchz28's Avatar
Power Park?
Old 04-13-2009, 11:27 AM
forcd ind's Avatar
if its like the B & M pro rachet, it has 2 do 2 clicks to get from rev to park, and 2 clicks from park to rev-the reason is the shifter is used for other appls., and i think in the instructions it might say when used in a mopar it doesnt do it
Old 04-13-2009, 11:41 AM
demonpixel's Avatar
Default Solved
Called Summit and they told me that it is indeed correct; there are two p's because it is a universal kit and there is a shorter throw on some transmissions from Park to Reverse than on others.
They also said that when it's all installed, if you don't use the LED light indicator, you will not be able to see the PPRND21, even in the daylight. So when it's correctly installed, the P that is not being used won't even show up.
