[PICS] Katech's Mosler MT900KR project
I thought you guys might like to see the progress of our Mosler MT900KR project. We basically took the MT900S street car and converted it into a track-day/HPDE machine.
Custom built LS2-based 427
Carrillo H-beam rods
Callies Magnum crankshaft
Katech pistons, just over 11:1 CR
DLC pins
GM Stage 3 cam
LS7 heads
Carbon fiber valve covers and coil relocation kit
Expected to make about 640hp.
Considering the car's light weight, awesome power, and phenomenal cornering ability, a proper dry sump system was high on our priority list. This features a custom made dry sump system with ARE pan and Dailey 3 stage scavenge pump. Internal pressure pump. The dry sump system was custom designed to fit within the space constraints of the Mosler and still retain the AC for those hot track days (the Mosler has almost no side window). Also a custom made alternator bracket to make space for the dry sump pump.
I'll post more pictures as things progress.
DLC pins
GM Stage 3 cam
LS7 heads
I would think with all that money in the car, he would have wanted to use nylon braided tubing to save some weight over the stainless. Another thing about the headers, they look a bit undersized for that kind of motor. Looks like 1 3/4" in the pictures.
that is bad ***.....but track car???? hell no...tag that sucker...it would make a great street car. if you need someone to test it for say a thousand miles or so...let me know.
