Lonnies dual pumps are in!!
Finally... I can spin my engine higher than 5,500 rpms with out running it out of fuel. Got my pump, harness, and hobbs switch on thursday and installed everthing this weekend. Lonnie did a great job, every thing was plug and play and top notch. Just took the car for a ride and it held 60psi of fuel pressure all the way to 6,800rpm's. A little back round, I had a single wabro intank with a hot wire first time to the dyno and fuel pressure droped to 20psi @5,000rpm. Round 2 was the same walbro intank with a KB boost a pump, 6,000 rpms fuel pressure was creaping down to the 35psi mark. Very happy with this pump, $600 well spent http://mycarpics.shutterfly.com/244
All pulg and play, 2 wires to the + on the battery, 1 wire to the - side of the battery. Hobbs switch plumbed to the brake booster line with my boost gauge and bypass. Hobbs switch has a plug for the racetronix harness.Fished the harness across the oem battey cables that are behind the radiator right down the abs box and ran in along the fuel lines. I mounted the 2 relays next to the oem plug for the fuel pump,(by the driver sway bar link) and then lonnie had a adapter plug for the fuel pump to the racetroix harness. Didn't have to cut a single wire.
Got a full meal deal system on order, twin pumps, lines, reg,rails. Looking forward to being able to go wot as last season drove car for engine break in with just a stock fuel pump and 60 pounders. Just kept the rpm down and kept it out of boost. Also couldn't really tune or check wot afr either.
