Help with PS pump return tube
I picked up a ps pump from an envoy and there is no return tube like on the GTO pump I already have. The return tube is a pretty small piece of tubing and costs almost $40 from the dealer.
Any other ideas? If I tapped it, what size thread do you suggest and what threaded fitting would I use?
Thanks,
Jeff
Thanks,
Jeff
from a V8 envoy? that should have had a plastic reservoir with it that has the return fitting on it (I actually have one in my garage). If you don't have one, then you'll need to tap that return fitting and use a remote reservoir from another vehicle. 1/2" npt will work.
yes, v8 envoy and it came with a tall plastic reservoir but it won't fit with my brackets. What size would you tap it and where would I find the right fitting for it?
