Starting my clutch install/replacement... **pics**
Ok so today i started the dreaded clutch replacement. Snapped a few shots of my progress so far...
heres my clutch disc.. its the AC Delco clutch kit..
started off by disconnecting the battery, removing the center console, shifter, etc..
next i jacked the the car up on some cinder blocks, loosened up the trailing arm, removed all trans/cross braces, unplugged all sensors,etc.. in the pic you can see i removed the slave cylinder and zip tied it up to the car so it didnt just hang
and if all of that wasnt fun enough...now came the REAL fun part
loosen all 8 bolts on the trans (the top 2 aren't that bad as long as you have about 2 feet of socket extension). then drop the trans and slide her out
if you try to do this without a tranny jack.. don't
o ya.. and leave the driveshaft tail in
That's all i got for today.. tomorrow i'll hopefully get the bell housing, pressure plate, flywheel, etc all off and get the flywheel out to the machine shop.
Village Troll
LOL... that mess looks all too familiar and it's such a joy to have to clean up while still under the car. Cheap cat litter and Mineral Spirits really work wonders for messes like that.
ya i threw some kitty litter on it last night.. hopefully it soaked it all up.. and ya i know i didnt have to pull the whole console but i figure less **** to work around when im boltin it all back up..
anyone got any feedback on the AC Delco clutch kit..??
1 Post
floor jack for me. I put a stage 2 in mine cause I dont ever want to do it again. she loves to grip
I had a nice long *** 1/2 to 3/8 extension and swivel sockets. so easy with an air compressor and an impact gun!
i've done it twice with no floor jack, just good old fashion muscle. probably woulda been a lot easier with a second set of hands or a good transmission jack. First time I didn't think about leaving the driveshaft in and soaked myself with fluid. Second time I left that sucker in for sure. Make sure you put some good break in time on that organic clutch.
If you are stock or near stock, that clutch kit will work fine.
Not too difficult once you get in there huh?
I've dropped my T56 many times. Every time I've done it by myself with only a floor jack, lol.
heres an update for today...
got evvverrything removed.. lots of oil everywhere. im thinking maybe i should put a new rear main seal in while im here..
clutch wasn't half as bad as i had imagined.. it's the original from 93 and it's been through some hell.. i thought i would be pulling out a thin wafer of clutch the way it drove
flywheel's off at the machine shop.. anyone think i should do the rear main while im here??
ya once that trans is out you have plenty of room to work around.. as far as taking out with a floor jack i give props to you.. it can be done just a lot harder..
P.S. Your engine is pretty damn clean compared to how my old one was.
ThoR294- well if it was the intake i know it doesnt anymore because i just took it out to paint and resealed it all up.. how could i tell if it was the oil pan?
and what do you have against fram???
1 Post
fram filters flow like **** its been proven get an acdelco pf454!
anyway, if everything else is clean then you are fine. I did my rear main seal when I did my clutch. I was just saying check everything while you are in there
