What anti-freeze do you guys use in your LS1s?
Old 04-14-2009, 03:45 AM
LS1nterceptor's Avatar
Default What anti-freeze do you guys use in your LS1s?
I yanked the radiator the other day and I'm going to put it back soon. What do y'all recommend using?
Old 04-14-2009, 08:23 AM
LS1_Unleashed's Avatar
Dexcool is the recommended coolant and the one gm uses in all their cars. If your flushing the whole system out you could use any coolant as far as i know, but I usually stick with dexcool. Couple more bucks but I do it for the peace of mind.
Old 04-14-2009, 08:30 AM
NonGoggleGuy's Avatar
The orange kind.
Old 04-14-2009, 09:09 AM
ccxxxxxxx's Avatar
Dex-cool is the devil...
Do a real good flush and go with the green...
Old 04-14-2009, 09:22 AM
Z Fury's Avatar
I run Dex-Cool. No problems with it in over 6 years, so why change.
Old 04-14-2009, 09:47 AM
sroach20's Avatar
new all makes/all models stuff will mix with anything. i ran that stuff with dexcool for a year with no problems. after the head swap i am now running universal only.
Old 04-14-2009, 01:47 PM
slvr98camaro's Avatar
i run prestone extended life 50/50
compatible with both dexcool, and the green stuff
Old 04-14-2009, 02:25 PM
slayerized6's Avatar
+1 ........
Old 04-14-2009, 03:14 PM
Sharpe's Avatar
Whatever cheap 50/50 I pick up at the time. 125,000 and no problems.
Old 04-14-2009, 08:16 PM
mild2wild's Avatar
Yep, me too...
Old 04-14-2009, 08:42 PM
boola1341's Avatar
prestone extended life 50/50 here also.
Old 04-14-2009, 09:50 PM
Why do you buy 50/50? You pay more, and get less... doesn't make sense.
Old 04-14-2009, 09:52 PM
sroach20's Avatar
its for the people who dont feel like getting distilled water and mixing it themselves.
Old 04-14-2009, 09:58 PM
Distilled? Are LS1 motors Catholics?
Old 04-14-2009, 10:51 PM
sroach20's Avatar
my car hasnt killed anyone.
Old 04-14-2009, 11:34 PM
Good call!
Old 04-15-2009, 08:27 AM
its like $1 more, and you dont have to sit there and measure the amount all of the time.. just dump it in
by the time you're done paying for the hydrometer and the distilled water, you are at about the same price
Old 04-15-2009, 08:37 AM
Mr Incredible's Avatar
Not using distilled water introduces minerals into the coolant. Some places have water that can cause problems, some don't, but any is worse than none. Minerals can precipitate out and cover interior surfaces, which reduces the transfer of heat. They don't do anybody any good.
Dexcool has problems in systems that are not airtight. Even coolant that goes out into the collection bottle and back in when cooling sees interaction with air. This is bad in Dexcool-land. The idea that it's good for 5yrs/100k miles leads people to think they will always get that much protection under all circumstances. Maybe. Maybe not. Failure of Dexcool produces brown gummy goo, and nobody needs that in their cooling system.
Changing over to green coolant is easy. Two-three year changes is no hardship. Peace of mind is good to have. I've never seen green coolant produce gooey and gummy deposits.
Cost? Most of you guys can't seem to spend enough on your cars so what's the problem with perhaps a couple of more bucks on coolant?
Quick Reply: What anti-freeze do you guys use in your LS1s?
