cam install gaskets
Old 10-27-2003, 06:45 AM
642642's Avatar
Question cam install gaskets
Can someone give me a run down of what gaskets im going to need to do my cam install? What I have so far:
Gaskets:
- 2 AIR tube gaskets
- 2 Water pump gaskets (From LS1howto)
- 1 front engine seal
Is that all I need?? Do I need one for the intake?
Thanks for the help guys.
Old 10-27-2003, 07:09 AM
02RED Z's Avatar
Depends on what all you want to change . You will be removing the valve covers [2 gaskets] , front cover [1 gasket] , crankshaft pully bolt .
Old 10-27-2003, 01:00 PM
642642's Avatar
I just want to put new gaskets in for what ever I have to take off to do the cam. Im also going to put in a new timing chain. Thanks 02RED Z Ill add those to the list. Anything else...
Old 10-27-2003, 06:00 PM
INMY01TA's Avatar
I'm curious as well as to what all I need. Thunders cam install package comes with valve cover gaskets as well as water pump/timing cover etc. Ive had the valve covers off before and I know that you can reuse the originals w/no problem. I wonder what else is necesary? I know you need a new pulley bolt.
Old 10-28-2003, 06:31 AM
jrp
SN95 Director
jrp's Avatar
buy the basic cam bolt kit from tsp, its only 30 bucks and comes with all you need . does come with air tube gaskets but i !air so i didnt need them.
Basic Camshaft Bolt & Gasket Kit
Includes GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets, GM Harmonic Balancer Bolt
