Drag Racing Tech
4L80 w/ RMVB & Transbrake questions
Old 04-14-2009, 02:41 PM
TexasVortexx's Avatar
Arrow 4L80 w/ RMVB & Transbrake questions
Guys, I am replacing the T56 with a 4L80 automatic and ordering a Neal Chance convertor. The motor is a Raymac built 408 w/ hydraulic roller that made over 650 on the motor dyno and has NX direct port nitrous with 200 and 300 pills. What 4l80 upgrades are you 9 second guys putting in your transmissions when built?
Thanks
Old 04-14-2009, 02:43 PM
GTFORMULA's Avatar
I just got my 4l80e and most guys just put red eagle clutches. If you want more they get some other upgrades. The trans is very strong.
Old 04-14-2009, 08:47 PM
Yes, I do know I want eagle reds. Im interested in which high performance hard parts other than a larger 300M input shaft should I be upgrading to?
I would also like to know what reverse manual valve body and transbrake is most in use here with the drag racers?
Old 04-14-2009, 11:17 PM
built408's Avatar
I hear the tpt trans brake works better then the rossler. Is there a reason for making it a manual vb? You really won't need any other hard parts, other then the 34 element intermidiate sprag.
Old 04-14-2009, 11:38 PM
no electronics to deal with is one of the reasons
Old 04-16-2009, 09:51 PM
ss_girl's Avatar
I don't think you can do a transbrake and mvb. Unless something has changed the TB only works when the tranny is in D.
Quick Reply: 4L80 w/ RMVB & Transbrake questions
