Corvette Performance - Z06
View Full Version : Z06
slo_lawncher
04-14-2009, 04:24 PM
Can someone tell me what the difference is between a Base model c5 coupe that does not have a removeable glass targa option, and a c5 Z06 coupe. I have seen in reading where they say that the z06 has a "special" roof. I understand that special is pretty vague. :confused::confused:
Badhawk
04-14-2009, 04:37 PM
Just google some images. Its pretty obvious.
desertLS1
04-14-2009, 04:49 PM
uhhhh.....:search:
So-GT0071
04-14-2009, 05:02 PM
http://i6.photobucket.com/albums/y240/carpathiandoomcows/MarkSwasonCoupe.jpg
http://i6.photobucket.com/albums/y240/carpathiandoomcows/photo.jpg
Googled it!
proporio
04-14-2009, 05:11 PM
Googled it!
Ooh, snap!
should have googled it:bang:
kain01
04-14-2009, 05:12 PM
Wow never noticed the glass, sail panel and everything is different. The non Z06 reminds me of the 62 rear glass in a way.
slo_lawncher
04-15-2009, 03:42 PM
Wow! ok yes now I see that the sail panel is different. But you can apparently make a stock rocker panel look like a Z06 by cutting a hole and inserting the brake cooling duct. Google you bastard, you will be my demise! Thanks for the help guys
CTSV_510
04-15-2009, 10:16 PM
It's referred to as a "fixed roof coupe" (FRC) or "hardtop" and they made non-Z06 C5s that way as well.
http://i81.photobucket.com/albums/j237/frcjim/vette/DSCN0003.jpg?t=1239851626
slo_lawncher
04-16-2009, 07:04 AM
AH HA! I had seen this picture and wondered if the rocker had been changed or what had happened:confused::confused: So I'm to assume it was a special order? How do you search to buy an FRC base model, non- Z06? Pretty hard to come by?
slo_lawncher
04-16-2009, 07:09 AM
Were these more common in earleir c5 models such as 97-99? It seems like almost every c5 came with a targa roof:bang: I told myself not make anything close to a clone Z06 but funds are tight and I wanna go fast, so If I could find an FRC, I would build it the way I want and probably add just brake ducts, but not badges.
02 Camaro SS
04-17-2009, 09:51 AM
They made FRCs until 2000. From whay I heard, they weren't selling too well so they just used all of those bodies for the Z06s which were made from 2001 to 2004 so the roofs on the C5 Z06s and the 97-00 FRCs are identical.
Benjamin Russick
04-18-2009, 02:16 PM
1999-00: The FRC was a stripped-down and cheaper Corvette. Z51 was standard and all were MN6 6-speeds.
2001: First year of Z06 on FRC body-style. 385HP and MN12 (different gear) 6-speed.
2002-04: Biggest change was 405HP, but lots of small ones over the run.
Here's a pic of my 2004 Z16, which shows the hard-top nicely in profile...
http://i108.photobucket.com/albums/n27/danziger69/niceside.jpg
SlowFRC
04-19-2009, 11:06 PM
Lots of mis-information in this thread about FRCs. The above poster definately has his information right though. I've heard that all 1999 FRCs came with Z51 suspension but not all 2000 FRcs came with it, I'm not sure about the accuracy of this. The FRCs are the most rare of the C5 models they only made 2.941 in 2000 and 4,031 in 1999. Check here for production numbers/more info: http://www.corvetteactioncenter.com/specs/c5/1999/99prod.html
Look around that site for more info on C5s in general.
SlowFRC
04-19-2009, 11:12 PM
I highly doubt that they used left over FRC bodies for Z06s. Whoever told you that should probably stop giving car advice.
slo_lawncher
04-21-2009, 09:19 AM
GOOD INFO!!! Thanks I am currently surfing the site you provided slowFRC. Thanks
chevyfanaddict
05-02-2009, 09:15 PM
wow... really?? Theres still people out there that have not ever noticed that? Its like night and day. I fricken :barf::barf: on the normal C5 roof. I would never own a vette that wasnt a Z06 or FRC.
02 Camaro SS
05-05-2009, 07:45 PM
Yea I thought it sounded kind of weird and I've never heard about that on here during the 5+ years I've been checking the site.
Tyler valo
05-05-2009, 08:44 PM
I can't honestly see why not. Not much is different from a base C5 and Z06, it's not like the new Z06 which is pretty much a completely different car. The C5Z has different tranny, Ti exhaust, 243 heads, different cam, stiffer suspension, gauge overlay and factory painted brake calipers.
Edit: front fog light cut out's and the rear brake ducts. The base C5 actually has the lines where to cut if you want to add the rear ducts.
noah98SS
05-10-2009, 10:08 PM
different windshield and back glass,LS6,not just different heads and cam,different rims and tires,just sayin
Tyler valo
05-10-2009, 10:56 PM
I knew the front windshield was thinner, didn't know about the back. The LS6 is nothing different than the LS1 besides cam and heads. After 00' all Corvettes got the LS6 block and intake. Yea the rims and tires are different, but wasn't the question just if they reused the FRC body?
