Tax return parts list. What to get????
Getting some extra cash and have 700 to spend (saving the rest).
What should i get?
My 93' A4 already has:
Hooker shorties and Gutted Y-pipe
PCM4Less tune
SLP LM1 exhaust with CME
Home depot Intake kit
180 degree thermostat
Lowering kit
EDIT: TB bypass, EGR, AIR delete.
What should i get?
PCM4Less tune
Lowering kit
Like Trav said too, 1.6 rr's would be nice as well
Oh man I would def do some 3.73 gears! They really wake the A4 up and especially since you've got 2.73. It's almost like going from stock manifolds to LT's...that's how I like to compare the difference in change/performance at least
What springs would i need for the 1.6rr's and pushrods?
Spring wise,,probably some Crane DBL valve springs or some Pac's. Some Trickflow or Smith Bro's pushrods as well.
Best bang for the buck would be the gears though.
Oh I don't doubt it. It's a night and day difference. Even the 3.42 ratio would be a nice change. I would only go that route if I did major HWY/Frwy driving.
Also what size rockers do i need the 3/8 or 7/16?
Haha yeah i feel so deprived.
Stock rocker studs are 3/8". You can replace them with 7/16" studs if you'd like. Self-aligning rockers would be fine.
im using stock springs with my rockers with no problem. plus if you can pick up a m6 rear end you could just swap the hole rear end. i only paid 150 for my rear end and i love my 3.42 gears. ive pulled 1.6's 60ft with my 3.42s
