cam choice and parts to match
Old 04-14-2009, 10:26 PM
litch2004's Avatar
Default cam choice and parts to match
I am currently changinging out my timing gears and chain and decided now would be a good time to upgrade my cam.
In my sig it pretty much has everything listed of what i have done and i was thinking about going with the cc503. is this a good choice or should i go ahead and go witt the cc306? if i do go with the cc305 what other parts ex. spring, pushrods, rockers, and lifters) would be my best coice.
I plan on upgrading to the LE2 heads and vortec SC.
I am working out of state so i have the money to go ahead and make my orders so any suggestions would be greatly appreciated.
Old 04-14-2009, 11:26 PM
IronOutlaw's Avatar
IF you are going with a supercharger then I would get a custom cam. IF you were staying NA id say the 306, Im going with either it or the newer 230/236 grind Comp has.
Old 04-14-2009, 11:47 PM
litch2004's Avatar
well the SC will be a little while. That is just the plan for the future so when that time comes i would trade up for another one. I just dont want to get a custom grind one now when i dont have the other parts to match.
Old 04-15-2009, 12:18 AM
mj114679's Avatar
well with any cam you go with you gotta get a stall!!! 2500 +stall speed... read the sticky it will tell you alot. i say go with the cc306!!!
Old 04-15-2009, 12:29 AM
StealthFormula's Avatar
This should help you get on track:
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Old 04-15-2009, 10:05 AM
myltwon's Avatar
sounds like you're getting way ahead of yourself on the planned mods
Old 04-15-2009, 07:35 PM
litch2004's Avatar
I already have a 3600 stall.
Old 04-15-2009, 07:42 PM
litch2004's Avatar
Like i said it will be a while till i send my heads off to llyod elliot and it will be a while one the SC. So since my engine is tore down to the long block and i am having to change out the gears and timing chain i want to change out my cam. I would like to go with the cc306. So what R.R., lifters and pushrods will be my be option.
And i was told when i got the car that the heads had been rebuilt (no proof to back it up) but they look like they might have been. I was also told that they had a small amount of porting done. I didnt think to look when i had the heads off.
Old 04-15-2009, 11:11 PM
litch2004's Avatar
well nevermind i have been spreaking with stealthformula and i am going to with the XE 230/236 and he suggested all the parts and part numbers that i need.
Quick Reply: cam choice and parts to match
