just bought a pro charger d-1sc
i have a 1998 trans am with a 408 with a m6 and 373s bought the pro charger through EPP cant wait to see how it runs! any opinions welcome!!! it made 440 at the wheels before !!!!
yea i hope so!! just had rpm transmission build a level 5 for me shifts awesome!! weak link is the stock 10 bolt haha 12 bolt moser on the way soon though! your car looks sweet also !!!
8 sec potential, 12 sec slip
Yep, its gonna be sweet! Do you happen to know what the compression is on your engine? Ideally, you want 9~9.5 with that setup. If you are running 14psi with higher compression, you may want to look into a meth kit. May not be a bad idea anyways even if you are in the target compression range.. Good luck with it all.
