who sells catch cans?
Old 04-15-2009, 10:58 AM
silverLSWON's Avatar
Default who sells catch cans?
i am looking to buy an oil catch can but i don't really know which ones actally work and who would sell them. the only one i can find is revextremes and i heard that one works pretty well. i also heard of amw i think??? just looking into my options for a catch can. also what sponsors sell them?
Old 04-15-2009, 04:56 PM
rel3rd's Avatar
I got mine off of this board from Mike Norris Motorsports. It works well.
RevExtreme one is supposed to be nice as well.
Old 04-15-2009, 07:11 PM
thanks!!! does it wobble alot when your car is idling?
Old 04-15-2009, 07:17 PM
vsocks1's Avatar
^^^^ I agree!!
Old 04-15-2009, 07:53 PM
rel3rd's Avatar
wobble? No. It's secured in the bracket by a set screw, and the bracket is bolted onto the cylinder head. No wobbles.
Old 04-15-2009, 08:35 PM
ok good, a friend of mine had the revextreme and it wobbles like crazy!
Old 04-15-2009, 08:58 PM
EndlessSummer85's Avatar
I have the Rev-extreme catch can and it's on there solid, no "wobbles" at all.
Old 04-15-2009, 09:13 PM
JFM-jr's Avatar
I like the REV Extreme setup I have.
Old 04-16-2009, 06:17 AM
toadzq8's Avatar
+3 for the Norris Motorsports can
Old 04-16-2009, 01:15 PM
Restricted User
WS6nJAX's Avatar
bump for the Norris catch can.
Old 04-16-2009, 04:01 PM
thanks for all the info guys. i'm prob going to order one before the weekend
Old 04-16-2009, 09:44 PM
chrs1313's Avatar
mine still seems to get oil in the intake and give me a little knock...so i swapped out the brillo pads for some S.S. wiremesh, and a fiberglass custom filter i made at work...same material used to filter oil mist from huge vacuum pumps to 3 microns at 99.97% efficiency...haha there should be no oil in my intake now
Old 04-17-2009, 02:21 PM
rel3rd's Avatar
I actually had to add a small inline filter in the other breather hose, since that one hooks to the throttle body and was drawing in some oil too.
Old 04-17-2009, 08:13 PM
bigdsz's Avatar
A coalescing filter is the only real way to stop oil from getting into the inlet manifold.
Old 04-18-2009, 11:29 PM
chrs1313's Avatar
once i see that term i know we are on the same page...
Old 04-19-2009, 02:55 PM
405HP_Z06's Avatar
Did you swap the line configuration with the modified filter material inside the can?
Old 04-20-2009, 11:05 AM
rich Z's Avatar
Wouldn't this cause pressure buildup once the filter soaks up oil thus causing oil leaks.
Old 04-20-2009, 02:07 PM
chrs1313's Avatar
I think what you are looking for is back pressure…and yes it will cause slightly more back pressure but this is true for any filter that is of higher efficiency…as long as the filter doesn’t cause as much pressure drop as what the intake manifold can pull there will be flow…and I don’t seeing this filter cause as much vacuum that will be inside of the intake…what is vacuum level in our manifolds…
Old 04-20-2009, 02:14 PM
chrs1313's Avatar
I am not sure if I understand your question, but yes everything is setup the same way and the filter is inside out flow…causing the oil to be filtered and pushed though the media…coalescing on the outside of the filter and dripping to the bottom…
Outside in flow would not work cause the oil would coalesce on the inside of the filter and have nowhere to drain…with this kind of setup outside in flow there needs to be a suction line on the I.D. of the element or a drain back flap will work too…
Old 04-20-2009, 02:33 PM
bigdsz's Avatar
A 20 micron borosilicate coalescing filter removes virtually all the oil mist in low volume-low pressure applications without saturation issues.
