Cruise control with drive by wire
I asked this before but can't find the post. I think all I need to make the cruise work in my 2006 5.3/ 4L60E drive by wire is some switches. who makes switches that will work?
I'm not sure this helps exactly but I have an Ididit column and had it semi-special ordered with thier a billet cruise/turn switch. The car is a '68 Camaro Convertible with a 2006 GTO LS2. The GTO cruise function is run through a powertrain interface module (PIM) and then to the PCM. The wiring diagram for the GTO and the cruise switch looks like it should work.
The bad news it that I'm not yet to the stage of running the wiring and starting the engine...
I think this is the switch that Ididit installed in thier column (although mine has a billet cover!). The molex connector coming out of the column is the same.
http://www.thecruisecontrolstore.com...0183/0018/3032
http://www.thecruisecontrolstore.com...0183/0018/3593
this should probably work
Yep! The key I've been told is open loop verus closed loop and that 80s vintage cruise controls work. T'were it me I would sent a quick note to John @ Sheartech.com... he could tell you in a heartbeat. There have also been some discussion on this issue in the past on this forum with more info. Good luck!
